Bem-vindo: Sáb Out 31, 2026 1:22 am
MensagemEnviado: Seg Jul 19, 2010 12:49 pm
Estudo troca do meu Pro4 por off.
Carro totalmente hopado. Todo de fibra e alumínio(tirando as bandejas é claro). Inclusive o diferencial traseiro e dianterio.
- HPI (#31411) Aluminium Center Cup Joint (F/R): http://www.rcmart.com/catalog/rc-pro4-a ... 12035.html
- HPI (#31413) Aluminium Spring Mount: http://www.rcmart.com/catalog/rc-pro4-a ... 11722.html
- HPI (#31418) Aluminium Battery Plate For PRO4: http://www.rcmart.com/catalog/rc-pro4-a ... 11726.html
- HPI (#31419) Aluminium Upper Arm Support: http://www.rcmart.com/catalog/rc-pro4-a ... 12037.html
- HPI (#31421) Aluminium Steering Crank Set For PRO4: http://www.rcmart.com/catalog/rc-pro4-a ... 12778.html
- HPI (#38202) Alu. Antenna Holder(PP): http://www.rcmart.com/catalog/rc-pro4-a ... 17341.html
- HPI (#73086) Graphite Bumper Brace: http://www.rcmart.com/catalog/rc-pro4-g ... 12782.html
- HPI (#75179) Alum. Input Shaft Set (Front And Rear)(PP): http://www.rcmart.com/catalog/rc-pro4-a ... 17822.html (na embalagem)
- HPI (#31404) Woven Grap Main Drive Shaft / 5m: http://www.rcmart.com/catalog/rc-pro4-w ... 11616.html
- HPI (#31422) Aluminium Bevel Gear Shaft (16T/Front): http://www.rcmart.com/catalog/rc-pro4-a ... 16181.html
- HPI (#31423) Aluminium Bevel Gear Shaft (16T/Rear): http://www.rcmart.com/catalog/rc-pro4-a ... 16182.html
- HPI (#6545) Shock Spring 14x25x1.5mm 5.75Coil (2pcs)(na embalagem)
- HPI (#6546) Shock Spring 14x25x1.5mm 5.5Coil (2pcs)(na embalagem)
- HPI (#6547) Shock Dpring 14x36x1.5mm 5.25Coil (2pcs) (RED)(na embalagem)
- HPI (#75184) Pro4 Hard Steel Uni Dogbone: http://www.rcmart.com/catalog/rc-pro4-h ... 18015.html
- HPI TC-D/Cyclone Heavy Duty Ball Cup 4.3x18mm[HPI-A302]: http://www.rc-mushroom.com/product_info ... s_id=19310 (na embalagem)
- Jet Cyclone/Pro4 Alum C Hub 4 Deg - Purple[JET-CYL-24P]: http://www.rc-mushroom.com/product_info ... s_id=16070
- Jet Cyclone/Pro4 Alum Knuckle Arm - Purple[JET-CYL-06P]: http://www.rc-mushroom.com/product_info ... s_id=12601
- Jet Cyclone TC Alum Shock Cap[JET-CYL-38]: http://www.rc-mushroom.com/product_info ... s_id=15625 (na embalagem)
- Jet Cyclone TC Alum Bumper Post[JET-CYL-36]: http://www.rc-mushroom.com/product_info ... s_id=15624
- Jet Cyclone/Pro4 Alum Rear Hub - Purple[JET-CYL-08P]: http://www.rc-mushroom.com/product_info ... s_id=12604
- Hot Bodies TC-D Diff Screw Set/Pro Spec Ball Diff 2.6mm TI Coated Diff Screw[HBS-67725]: http://www.rc-mushroom.com/product_info ... s_id=19212
- Square aluminum bevel gear front: http://shopping.rcmodel.hk/popup_image. ... 19&image=0
- NK Engrenagens aluminum bevel gear
- NK Engrenagens steel DIFF OUTDRIVES
- Zeppin Racing 2x6x3mm Ceramic Thrust Bearing 2 Pcs[ZR-F2-6/C]: http://www.rc-mushroom.com/product_info ... s_id=17345 (na embalagem)
- PRO4 Diff Screw and Heavy Duty T-nut set: https://www.ssl-stormerhobbies.com/cgi- ... n=HPI73522
- PRO4 Front SOLID AXLE (SPOOL): https://www.ssl-stormerhobbies.com/cgi- ... n=HPI75168
- PRO4 DELRIN DIFF OUTDRIVES: https://www.ssl-stormerhobbies.com/cgi- ... n=HPI75169 (na embalagem)
- PRO4 PIVOT BALLS, delrin (8): https://www.ssl-stormerhobbies.com/cgi- ... n=HPI75172 (na embalagem)
- PRO4 Delrin BEARING ADAPTERS (8): https://www.ssl-stormerhobbies.com/cgi- ... n=HPI75174 (acompanha tb os rolamentos, tudo na embalagem)
Vorza Imagem Xray XT8 Imagem
4Pk
Editado pela última vez por Germano em Seg Ago 02, 2010 1:25 pm, em um total de 5 vezes.
MensagemEnviado: Seg Jul 19, 2010 1:00 pm
Registrado em: Ter Jan 20, 2009 8:42 pm
Germano, que carro Loco velho!
HPI VORZA!
MensagemEnviado: Seg Jul 19, 2010 1:09 pm
Pois é, tá dando dó pois investi uma fortuna nesse carro mas não tô resistindo aos off. Ainda mais sem pista pra andar. A caixa dele tá entupida de peças extras.
4Pk
MensagemEnviado: Ter Jul 20, 2010 6:27 pm
E ai cumpadi, ta pedindo quanto?
MensagemEnviado: Qua Jul 21, 2010 9:20 am
Cara, tem tanta coisa no carro q não sei dizer. rs :lol:
Mas tô a procura de um buggy.
4Pk
MensagemEnviado: Qua Jul 21, 2010 1:09 pm
Registrado em: Dom Jun 21, 2009 11:05 pm
Boa tarde !
O que acompanha ele ? Obrigado.
Carros: HIMOTO MEGA E8MTL 1:8 RTR BRUSHLESS / HIMOTO MEGAP MXT-2S 1:8 NITRO SH21
Qualificações:
viewtopic.php?f=3&t=22429
Parque Witeck ! Um espaço dedicado a natureza!
http://www.parquewiteck.com.br
MensagemEnviado: Qua Jul 21, 2010 4:47 pm
Registrado em: Sex Out 30, 2009 8:25 am
Olá Amigo.
tenho um tamiya df-03
acabei de montar e pintar, roletado, completo com combo brushelles 3600kv tudo sem uso.
se interessar mando fotos, é um belo buggy !!!!!
abraço
Rangel
Rangel
MensagemEnviado: Qua Jul 21, 2010 6:32 pm
Manoeliot escreveu:
Boa tarde !
É o chassis com ou sem o combo novak 3.5. Acompanha tb uma bolha tamiya silvia s15 nova, nunca usada com sistema de iluminação instalado.
As fotos não ficaram boas mas a bolha tá linda.
4Pk
MensagemEnviado: Qua Jul 21, 2010 6:56 pm
Shom !!! parabéns !!! quanto ?
Qualificações:
MensagemEnviado: Qui Jul 22, 2010 8:59 pm
Registrado em: Dom Ago 23, 2009 3:03 pm
Amigo,
Vc aceita trocar por uma E-revo 1/16, 4x4, carro zeradinho com manuais...
Obrigado!
MensagemEnviado: Seg Ago 02, 2010 1:26 pm
O carro foi negociado.
4Pk
